RCU Forums - View Single Post - Which engine/string trimmer should I get?
Old 08-18-2013 | 01:17 PM
av8tor1977's Avatar
av8tor1977
The carb should fit/work. You might need to port the plastic insulator where the carb mounts to the same size as the carb throat outlet for best results, and if the pulse holes for the fuel pump don't line up, you'll have to deal with that. You can make a groove to send the pulse where you need it, or just convert to an external fuel pump pulse line. Easy to do...
AV8TOR
