RCU Forums - View Single Post - OS .10 Trainer
Old 08-18-2013 | 03:01 PM
  #65
flyingagin's Avatar
flyingagin
I sorted out my fuel system. I rebuilt the tank. The two brass tubes now make 90 degree bends immediately out of the tank, so the lines clear the engine, no rubbing.
I started the engine on the patio and adjust the hs needle. The idle air bleed screw needs to back out a bit. And the plug is no good. Will only run with the igniter attached. This engine last ran in the nose of a power glider back around 95.
I hope to try to fly again next Saturday.
Ken
