Cool,
you are still testing this engine
you don't flip start it by hand do you?
open exhaust?
you took the muffler off?
that was only good for 500 rpm?
Was it LOUD???
you did not try the wood 12 X 5 prop that came with the engine?
I plan to remove the carb and replace with a .65 spray bar and needle valve in the carb mounting holes
using a stretch tubing type bladder
for control line
Red line for this engine is 12,500 rpm from the spec sheet I sourced on line.
I would like to prop it to get 12,000 in the air
not sure about running a muffler
I don't have to
and lighter is better
but how loud are we talking here?
Buzz
Originally Posted by
1QwkSport2.5r
I got my hands on some "civilian" Carburetors for my Sportsters and went on a prop testing spree.
74*F/64% humidity, 5%nitro 25% castor, McCoy MC59 plug, APC Props, factory sportster muffler.
11x8 11,700/2,400
11x9 11,600/2,280
12x6 11,550/2,300 (12,000 open exhaust)
12x7 11,100/2,100
13x6 11,100/1,950
13x7 10,600/1,950
13x8 9,900/1,800
