RCU Forums - View Single Post - Flashing Codes
Thread: Flashing Codes
Old 08-20-2013 | 11:58 AM
Chessiegolf
Tom,
Thanks for the information, I've now upgraded the receiver to v2.63 and the flashing (which was on the DV4 module) has now stopped.
Interestingly, even though I had saved the original model configuration and then reloaded it, after rebinding a couple of the channels no longer worked. I could see the input on the x axis but there was no output on the y axis. On one channel there was an output which had reversed itself and reversing the channel, or the sevo, in Gigacontrol had no effect. After a while I discovered that if I unassigned the faulty channel and then reasigned it, the output returned to normal.
Hopefully no other gremlins will creep in, but everything right now appears to be working ok.
Thanks again for your help.
