RCU Forums - View Single Post - Beginner at 66
Thread: Beginner at 66
Old 08-22-2013 | 02:43 PM
Gray Beard
My Feedback: (-1)
For threads on building you may want to use the search engine in the kit building forum. I remember seeing a number of build threads on the PT-17 over the years. As Tom said, you may be a bit over your head on this one and I'm sure if you just phoned Nicks shop they can get you a set of plans and instructions. Once you get those you may want to ask around and see if you can borrow an incidence meter {or two} from a club member. The meter is a must have tool if your into building Bipes. The 17 must be built straight and true if you want a good flier.
Check out the building forum.
