Originally Posted by
orthobird
i figured it out.
i am using the Jr 922x powersafe receiver.
i found solution on another thread on another website, i cannot mention the name of it here, but it deals with things that fly and that are very big.
here it is
this is what i had to do.
i used a y harness, plugged the tm1000 into the y then into bind/data.
i then put bind plug into the yharness
then
i switched it on
then all of the lights of the satellite Rx were blinking, except, the TM1000 were not and neither were the lights on the Rx on.
then, i unplugged the y harness from the Rx (while the satellites are still blinking),
then, i got a 6.0 volt battery, i plugged the tm 1000 into the data port on a standard 2.4 ghz receiver, then plugged the battery into the receiver, and now, all lights are blinking on the satellites and on the TM 1000
then i did Tx bind
and immediately it all worked.
while Rx for plane was still on, i unplugged TM 1000 from spare Rx, and then plugged it back into the airplane Rx data port, then i played with it
and it is awesome.
i am using optical RPM sensor, and the reading was way high, just with me spinning the backplate, it was reading over 10,000
so i don't know how to fix this yet.
but now i know how to make it work on my powersafes and on the power box!!
What???? that's way too complicated, no?
