RCU Forums - View Single Post - 9C to 6XAS training setup
Old 09-24-2003 | 11:01 PM
sbenter
Default RE: 9C to 6XAS training setup
Ok let me get this strait... If I am using the 9CAP (PCM) as Master then the 6XAS has to be set to FM/PPM? OK then If the 6XAS (FM/PPM) as Master do I have to change the 9CAP to the same modulation? I am a little confused if the slave is never powered on isn't the Modulation taken then from the Master?
