Superb job Neddy. Your on the homestretch now.
Just from experience. When you put the landing gear back together take a dremel and clean out the holes where the main pins go. If you try and press the pins thru without prepping the hole you can press the paint off. I prepped both the mounting blocks and the holes thru the main gear.
You happy with the Klass Kote? It is some of the best paint I have used.
SunDevilPilot
