I am curious about what is the reasoning behind this type of setup? What are you using this for?
If you were to have a control horn or pushrod failure at the control surface you are done. This could likely create a problem that you are trying to avoid.
With the usual 1 servo per elevator half that would not happen.
Perhaps this is for an unusual plane which is why I asked.
