RCU Forums - View Single Post - birgers HL-Tiger I 313 from rookie to___?
Old 08-27-2013 | 05:28 AM
beppel's Avatar
beppel
And now letīs create some welding lines.
Take some 2 component putty and form small lines. Then follow the pictures.
Take a small putty knife and add a little wave structure.
The ones I did could be much better. But for the first time….
Now the turret is completed.
Letīs do some changes to the upper hull. First the drivers vision port. Letīs open it.
This one is a new one from a supplier. We just need to glue it to its position.
Take the filler and the brush and repeat the turret procedure to the hull.
Side walls and front speckling and turning, engine grids, machine gun ball mount and drivers port just speckling. Then grinding.
Again, adding some welding lines.
