The quality of the connectors is more important than the gage of the wire. If the connector has poor contact between the parts, a large voltage drop can occur in the connector itself, much greater than the drop due to wire resistance. That is why gold plating and high spring tension is very desireable. Also a large mating surface is preferable.
