If you read AA5BY's posts you'll see that he had to move this servos inside near the CG to get it to balance. He's running a G20EI. He added no extra weight. Another pilot here mounted a 26cc engine and moved his servos inside the fuselage to get it to balance. Based on the experience of those two builders alone, I'd say a bigger engine will make it nose heavy.
RJ
