Sounds pretty cool, any pics??
I was considering cutting one from aluminum, but then I found the original that I had put somewhere safe
I had good luck rough sawing most of the excess then grinding/sanding to final size, but I've been practicing. Next step is to chuck up the crank case and turn down the front nose to minimum thickness.
