Hi Gary, hope your still having fun with the Turbinator. I finally balanced mine. I had to put 3 1/2 lbs. of lead in the nose and I already have two 3 cell 5000 mah Lipo batteries plus a A123 battery in the nose. It is going to weigh around 40 lbs dry. I was reading your post #310 that you had to much control on elevator and ailerons. What throws did you end up with on elevator and ailerons?
Jeff
