Originally Posted by
M113apc
I ran my new motor for the first time, after throttling up the motor quit after a few seconds.I throttled down and then up again and the motor quit again after a few seconds...???
What battery do you have.. those symptoms suggest that your battery voltage is dropping too far and you are hitting LVC.
.. or that your ESC is set for 4s when you are using 3s, [or set for 3s when you are using 2s] and the voltage is too low from the outset.
