RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 09-03-2013 | 05:23 AM
  #6578
JohnB96041's Avatar
JohnB96041
Originally Posted by ahicks
I've flown Funtana 125's with both a 20 and a 30. The only time you can use the full power of the 30 is when you're pointed up! The 20 is lighter feeling, much more civilized, and every bit as much fun. Given the choice, I don't believe the 30 is the 'go to' engine for that airframe anymore. It was more commonly used before the 20's were available?
I agree 100%.....I have 2 of the Funtana 125's. One with a SAP180 30cc and one with the DLE 20cc. The 20cc model flys like it did with the Saito 1.25 4s but with more authority and power. The one with the SAP180 30cc is way over powered. It takes off around half throttle and flys at half throttle most of the time. Due to equipment on board, the 30cc model weighs 11.5 lbs the one with the 20cc weighs 9.5 lbs.
