Originally Posted by
j301
This is disconcerting, the information that contradicts the only other available info is coming from the distributor. If I were to need to set the timing to 28 deg btc, I would have to drill and tap two more holes to move the sensor. Perhaps Xairflyer, if you could, check your timing since yours it the only one running so far and let us know?
I done a quick test on mine last week just using spark and degree wheel and it was around 31deg, I have just went out to the workshop and checked mine again using the RCexl buzzer and CH ignitions degree wheel mine is set at 34deg.
My pickup is between the two webs on the engine, in fact the top and bottom of the pickup line up perfectly with each web.
