Hi,
My plane had a tendency for the right wing to drop when pulling quick up for example. I corrected it by adjusting in flying and adjusting weight of left winghalf, and also adjust the neutral on right and left elevators. It took a while - maybe 10 flights and adjustments, before I was satisfied. I used a Hangar 9 Angle Pro digital inclinometer first to get close to equal throws up/down and same 0 value for neutral on both elevators and then fine adjusted after flights in my transmitter on each individual elevator neutral. The problem is not 100% gone but rather good now.
That is on my MythoS 125E.
/Bo
