RCU Forums - View Single Post - k&b .40 4011 doing something different
Old 09-06-2013 | 11:42 AM
earlwb's Avatar
earlwb
Originally Posted by franktheetank
Here's a question just off topic, what makes the engines rated 2-4 HP so much stronger than these 1hp and less?
You sort of answered your own question.a 2-4hp engine is more powerful than a 1 hp engine.
But with the engines, the manufacturers do all sorts of arcane things to make their engine seem more powerful to the buyers. It is all marketing stuff.
The basic trick is to use a slightly more thin propeller which is a little too small for practical uses, and then use more nitro methane, and run the engine without the muffler so they can get the maximum RPMs that the motor can put out. Then they calculate its HP based on that. In real life with a realistic sized propeller and a muffler on the engine, it won't even come close to their advertised HP claim. Many of those so called 2 hp engines don't usually put out much more power than a regular engine does with all things being more equal.
