RCU Forums - View Single Post - Airflow visualisation
Old 09-09-2013 | 12:20 PM
  #62
Alex Voicu
Default Fin fences test (version 2)
Anyway, instead of giving up on the fin fences, I went back to the images from the previous tests. I noticed that without the fences, the airflow is pretty straight near the leading edge and only goes spanwise in a clearly delimited area:
The obvious conclusion was to try a new type of fence, one that goes from 0 width near the leading edge to full width near the rudder hinge line. I quickly removed the fences from the model, reshaped them right there on the field and put them back on for more tests.
I didn’t expect too much from this, but I was very surprised to see the results are clearly superior to the previous version of the fences and also showed a marked improvement compared to the normal configuration (without fin fences).
I tested the model with and without the camera and the rudder is clearly more powerful, especially on KE loop exits (last quadrant) I can be more relaxed, the model is smoother and comes back to horizontal KE much easier.
ID:	1918402   Click image for larger version
ID:	1918403   Click image for larger version
ID:	1918404   Click image for larger version
