RCU Forums - View Single Post - Newbie Need help.
Old 09-09-2013 | 04:18 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Originally Posted by Griffin_NC
I just finished a Aero Advante with my boys for the first car. It runs greats and is loads for fun. Car, Batteries, and Radio from Tower Hobbies for around $260. I'm using a Futaba T3PRKA radio and a standard S3004 futaba servo with it. The frog was on my list as well, but I wanted to go with 4wd. The Avante has the newer ESC then the others. I like Tower cause they always have discounts and free shipping for most their stuff. I used them a ton when I was flying planes.
You do this mod?
http://www.rcuniverse.com/forum/rc-e...m-chassis.html
If not its a good thing to do haven't snapped a chassis on either of my DF-02's since I did it. And they were through quite a bit. That fix's one of the few real weaknesses I've had issues with on the chassis. I've done plent of other things, but those were mainly for performance, or to help it survive the brushless setup I threw in
Side note I'd recommend a DF-02 over a frog as its a more modern chassis, it can take a decent beating, and you can do a few different things to make it different. Like I have one set up as a stadium truck with truck tires on it
My Brushless one has been in 2-3 full speed crashes, and only thing that happened was I lost part of a shock (my nephew turned into it head on when I was doing a speed run thinking it was funny) Still drove it for 20 mins missing a shock as the BL setup I run pulled the front end up enough where it was drivable
