BTW -
B - the 100A/1200W server (actually, a measly 75A/900W at 110V if you don't mod the voltage regulation
) PSU is DEAD EASY; even Jonesey could do it.
Look here:
http://www.rcgroups.com/forums/showt...0#post25200780
Ignore the stuff about isolating the ground; those peeps are just doing that so they can series-output these for 24V to run the UBER-CHARGERS those crazy folks use for their 6-12S packs on the monster helis & 1/5 scale mud buggies. Mine is a bit more sophisticated; I added 4mm banana jacks and Switch & Voltmeter and hacked it to 13.5V, etc. But U can have one of them up & running in 5 minutes if all you want is 12V as if running from a car battery; all u need is a resistor in the 470-1KΩ range. Easy-peasy.
Here's where I bought mine for $17 shipped:
http://www.ebay.com/itm/HP-438202-00...item4170be2146
Those of you NOT in the US should search for HP 438202-002 or 438202-001 or DL580 Power Supply.
When I have a chance I'll post pics of mine all done; it cost me less than $30 for everything, including the panel meter from China.
mnem
Pray for me. Or don't.
