Originally Posted by
frema
ohh now i have to ask you something
did you realy checked the valves
i know from experiance that the valves can be a real pain
they seems to be working ,but they let only half of the feul trough
maybe you can try a start without the valve
i can recomment you this pump , but maybe its no use if the valve block is not good
let me know ok?
Kind regards
Martin.
Thanks for the adress. Yes,I have tried running without the fuel-valve. No different, so the solenoid-valves are not the culpit. I thought of testing with a pump from one of my larger turbines (not for use with the kolibri - just testing) will that be OK or will I harm the engine?
