Still, you should be able to make it run okay I think. Is the centerline of the tank fairly well matched up with the carb spraybar, or a little below it? Some folks have had success increasing the muffler pressure by crimping the ends of the exhaust down tubes slightly. Also, try adjusting the engine at full throttle when pointing the nose straight up and see if that helps.
