Yes, without a pump or regulator it is inevitable that your engine will lean out some on up lines, and it will be worse as the fuel burns off. Moving the tank back farther from the engine will not help, it will make it even worse because in the vertical up position the fuel has to be drawn up even farther than before.
Jim
