What voltage are the servos rated for?
What was the end of charge voltage of the Battery?
Generally, the "goo" indicates that a very high current condition existed.
(Not to mention the smoke)
It's quite possible that servos rated at say 5 to 6V saw a higher voltage, and the internal capacitors blew, resulting in the "goo",
and a high current short. It may be possible to dissect a servo that has some goo around it, and check for vented/blown capacitors.
It's even possible that replacing the bad capacitors might repair the servo(s).
It's also possible that the shorted components reduced the voltage and confined the damage.
