RCU Forums - View Single Post - Airflow visualisation
Thread
09-19-2013 | 04:42 PM
79
mithrandir
My Feedback: (
2
Jul 2003
1,193
adelanto, CA
I am gonna suggest the fences are in this instance behaving as vortex generators.... there is a pretty good AOA (wrt fences) and you are seeing the vortex.... but prolly no significant regions of seperation
Quote:
Originally Posted by
Alex Voicu
Finally here are the results from the fin fences and canalizer test.
Since the airflow was almost symmetrical on the left and right sides of the fuselage in previous tests, I decided to tuft only the right side and concentrate on the rear fuselage and tail area. Fin fences obviously don’t have any influence on the airflow around the nose section, the canalizer may have but only for a small area on the canopy.
I initially built and tested 2 fin fences, shaped as seen in the image below. They have a constant width and follow the shape of the fin airfoil.
I expected some visible improvements in right rudder KE maneuvers, but the results were disappointing at first; in KE horizontal flight the spanwise flow was indeed limited by the fences in the trailing edge area, but I could see some turbulence near the leading edge, probably caused by the front end of the fin fences.
In KE loops it was much worse, you can actually see the disrupted airflow caused by the 2 fin fences:
Reply
Like
mithrandir
View Public Profile
Send a private message to mithrandir
Visit mithrandir's homepage!
Find More Posts by mithrandir
View iTrader Profile
