RCU Forums - View Single Post - Airflow visualisation
Old 09-19-2013 | 08:08 PM
  #80
Alex Voicu
Originally Posted by mithrandir
I am gonna suggest the fences are in this instance behaving as vortex generators.... there is a pretty good AOA (wrt fences) and you are seeing the vortex.... but prolly no significant regions of seperation
Thanks a lot for the videos, results look similar. For example, at 2:20 in the first video (KE flight) you can see the airflow going around the top and bottom of the fuselage, moving from the high pressure side to the low pressure side of the fuselage. This makes the fuselage inefficient as a lifting device.
Yes the fin fences do much more than directing the airflow, but the fin tip does stall in high AOA knife edge maneuvers, probably because i used a thin airfoil. This is why i'm going to use thicker airfoils at the fin tip for my future designs. Fortunately i did just that for the kit version of Radiance (although for the wrong reasons)
