OK guys.....
Has anyone built one of the newest versions????????? Here's the deal....
The wing attach points are supposed to be re-enforced with a hard wood dowel. In the instructions, it says to use a 3/8" dowel, and insert it into the hole in the front, and to just use thin CA to harden the rear holes. But, in my wing, there are 3/4" recessed holes cut, on both the front and the back.
The real kick to the nutz is... the hardware pack still only had the 3/8" dowel, and the flat plywood plate for the rear holes. Obviously both are useless.
I guess I need to go buy a 3/4" dowel, and make fillers for both the front and rear.
I'm not looking for a solution... but just wondering if anyone else has a kit like this.
