Originally Posted by
ekir
I have search fairly well the subject on how to remove the plug cap on a DLE 35. I can get it pushed on with a small twist, but finding it very difficult to remove. Anything I am missing anything, except the strength needed to pull it off?
Finally, the big spring in the cap has come out when I finally removed the cap with lots of pulling. Is this spring really needed for the ground?
Ed
Ed, this has been discussed several times and fellas have come up with various solutions. Most of these require that the spring circ-clip be tossed. Some like to use a worm gear clamp to hold the cap.
I tend to go the simple route. I remove the circ- clip and add a piece of silicone rubber tubing onto the cap to hold the cap in place of the clip. Removes easily but holds firm.
I don't use the extra spring that's included for contact.. In my experience it isn't required.
