RCU Forums - View Single Post - Thrust Angles
Thread: Thrust Angles
Old 04-26-2002 | 03:48 AM
researcher's Avatar
researcher
Default engine thrust angle shims
For 2 degrees down thrust, I place two flat washers on each of the rear engine mounting bolts, UNDER the engine's mounting flange. For right thrust, I add 2 flat washers under the left side of the motor mount (on the firewall) to shim it to the right. Also, it is better to add MORE down thrust & right thrust, than it is not add enough. More won't hurt. Joe V
