RCU Forums - View Single Post - 2008 the year of the Turbinator
Old 09-29-2013 | 05:21 AM
  #248
KJ-66
Hi hooker53
Thankyou for your reply. I will be using savox servos on all the flying surfaces. The servos are rated at 16 Kg torque @ 6 Volts. I believe that the assembling process,will be fairly quick,once all the cutting out of the wooden formers etc,has been completed? I bought all the required balsa wood,but could not get 1/8" plywood sheets,here in South Africa. So I have to use 3mm plywood instead of 1/8" thickness.
Regards
Craig
