Thanks guys.
T-55, I thought about that but I'm skeptical of radio interference from running ignition battery leads down the wings. Did you have any trouble with your set up?
Bruce is a good guy to work with but it's way too late in the build to change the length of the struts. The wheels when retracted just barley fit and are 1/16th away from the formers as is. And I would have to put even smaller tanks in the nacelles. Another reason to build the 14' er. over the 12. One should be able to put the tanks in the wings at that size.
