"I had the system set up in mix mode, this allows the instructor to help the student out with out actually taking full control. Most were not using enough elevator in the turns and the nose was dropping, so I could just help lift it a little as required. The student never knows that you helped unless you tell them"
Flyinfool, thanks for your post. Great job, and the jet segment of our hobby owes you a debt for your ambassadorship.
Question: The only training Setups I am familiar with are "all or nothing", and your mix mode is something I haven't stumbled across until now. What equipment are you using? Thanks again for your efforts.
