RCU Forums - View Single Post - School Project - Help
Old 10-01-2013 | 09:59 AM
aeajr's Avatar
aeajr
A note on take-off, they only have 40 feet of take-off permitted so the plane will have to come off the ground pretty fast.
I did some modeling of motors using WebOCalc - using a 230 kV outrunner on 24 cells/28/8V with a 15X10 prop you would pull 15 amps and produce 74 oz of thrust and 50 mph pitch speed on 432 input watts.
http://www.maxxprod.com/pdf/HC6332-230.pdf
If your plane weighs 6 pounds all up that would be about 72 watts/pound. That should get the job done.
Now, you don't have to use THIS motor. It is just for reference to get a starting point.
Similar results on this 200 kV motor with a 16X12 prop at about 69 watts/pound.
http://www.himodel.com/electric/EMAX...GT5335_10.html
