Originally Posted by
Bob Paris
Hi,
I've a 10 channel Rx installed into a gas F6F and unable to get the RCEXL kill switch to work. I've set limits to 100% and I've the light to show when unit is on and light to go off, when unit is set to the engine kill position. I've tried everything I can think of...but the engine kill unit will not function at all.
Is there a problem with the RCEXL kill switch, interfacing with Airtronics equipment ?
Any help will be appreciated.
Soft Landings Always,
Bobby of Maui
I don't have any problems with my RCEXL kill switch on FH3. Did you set both limits to 100%? One should be at -100% the other on 100%. Check your SX MONITOR.
