RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 10-02-2013 | 10:04 AM
  #1434
izzy
Originally Posted by Dave Wilshere
The EDF Hawk I'm getting close to finishing has the worst wood positioning I have seen, I've emailed the boss about it and hopefully it will get fixed for future kits and the Hawk I have just ordered.
The wood has always seemed off set, the openings are not equal around the CL. But normally a small notch (like on my original) is enough, this one is by far the worst of the four Hawk's I have done. Set the unit position with the inner gear doors fitted and wheels/legs in place.
Yes, I just tap the plywood (on all my CARF models) No spike nut. I use a new sharp M4 tap in a 9.6 or 12v drill. Drill 3.2mm and tap straight through. Hand taping is not a option as you wave the tape around too much and work the hole larger. I don't add thin CA as I have never found it necessary. I can crank the screw down tight on just the plywood.
My thoughts have always been if you rip the thread/screw out you can still fit a spike T nut. If they are in to start it takes the whole wing out!
Dave
looking at your pics, i must admit i would not accept this. needing to cut into the outer skin of the wing where the doors dont cover is just not acceptable
i bought the 4mm tap today , and will work on it later tonight ( if i get home from work ) but if i need to cut into the wing itself, i will request a new wing from CARF and have the current one sent back if needed
i think i will use CA to harden a it the ply( my feeling of security )
will add pics later tonight
izzy
