Bryan what kind of valves do you use to do what you are doing? I kind of picture what you are saying but the only valve I have that (I THINK) would do what you are describing is a Spring Air UP valve, a one way so to speak.
In other work I have done I have seen what you are describing. The oring will not seat in the groove correctly unless there is a lot of differential pressure on it.
