Originally Posted by
robart-joe
The electric trunion is now CNC machined and uses set screws instead of the slit tube and clamp screw. These have offered much higher precision. As we use up stock of the standard pneumatic trunion, this electric trunion (double pins and set screws) will be used in both gear.
Appreciate the reply; I have a brand new 'Pneumatic' set, still in the box, unused, havn't started building my FW190, I received them from Tower Hobbies on Aug 28; I would assume has the older set up, any way to trade these in for an upgraded version or the parts needed to upgrade, or send them in for an upgrade, before I actual use them and incurr any problems?
Thank You.
