The block of wood in the fuse that the wing bolts go into, one of the holes is finally stripping out, any problems putting a blind nut on the top of it? Thinking that would be a pretty permanent cure.
Also, what are you guys using to hold your wing on? I have two metal bolts as I couldnt find any nylon ones long enough.
