If this is the DGA-12 you are referring to I would go to the top end of the
suggested power range, 40cc. as this big airplane has a lot of inherent
drag factor with it.
DLE35 or RCGF40 Twin
[TABLE]
[TR]
[TD="colspan: 14"]
[TABLE]
[TR]
[TD]
Specification
[/TD]
[TD]
Description
[/TD]
[TD="width: 27"][/TD]
[TD="width: 18%"]
Specification
[/TD]
[TD="width: 30%"]
Description
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Wing Span:
[/TD]
[TD="class: bdytext"]95"(2400 mm)
[/TD]
[TD="class: bdytext"]Control Horns:
[/TD]
[TD="class: bdytext"]Included (Tower Control Horns)
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Wing Area:
[/TD]
[TD="class: bdytext"]1398 sq. in (90 sq.dm)
[/TD]
[TD="class: bdytext"]Canopy:
[/TD]
[TD="class: bdytext"]APC(Included)
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Weight:
[/TD]
[TD="class: bdytext"]12 lbs (4972g)
[/TD]
[TD="class: bdytext"]Wheels:
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Length:
[/TD]
[TD="class: bdytext"]69"(1750 mm)
[/TD]
[TD="class: bdytext"]Wheel Pants:
[/TD]
[TD="class: bdytext"]Fiberglass (painted)
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Fly Weight :
[/TD]
[TD="class: bdytext"]16-17 lbs (7300-8000 g)
[/TD]
[TD="class: bdytext"]Fuel Tank:
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Engines:
[/TD]
[TD="class: bdytext"]1.0 - 1.6 glow 0r 1.6-2.4ci(26-40cc) gas
[/TD]
[TD="class: bdytext"]Landing Gear:
[/TD]
[TD="class: bdytext"]Aluminum
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Covering:
[/TD]
[TD="class: bdytext"]Oracover(Ultracote)
[/TD]
[TD="class: bdytext"]Push Rod:
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Radio:
[/TD]
[TD="class: bdytext"]4 Ch 8 Servos
[/TD]
[TD="class: bdytext"]Hardware:
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Cowl:
[/TD]
[/TD]
[TD="class: bdytext"]Decals:
[/TD]
[/TD]
[/TR]
[TR]
[TD="class: bdytext"]Motor Mount:
[/TD]
[TD="class: bdytext"]N/A
[/TD]
[TD="width: 18%"]Servo Plate:
[/TD]
[TD="width: 30%"]Included
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD="width: 14"]
[/TD]
[TD="width: 34"]
[/TD]
[TD="width: 66"]
[/TD]
[TD="width: 25"]
[/TD]
[TD="width: 100"]
[/TD]
[/TR]
[/TABLE]
