RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 10-05-2013 | 03:53 AM
  #6616
allans
Originally Posted by microdon2
I recently rebuilt my DLE 20 - the needlebearing on the crankcase was going (exhibited by a loud squeaking sound when running). (once I got it apart the needle's just fell off the bearing.) Also changed the two main bearings. Engine ran great for a couple of runs, but now it dies at top end, maybe even middle throttle. I've opened the HS all the way up to 3 turns - its' better, but still dies at WOT. So sounds to me like it's being starved for fuel. Took the tank apart tonight in case the tank filter klunk was clogged - wasn't, but changed klunk anyway. Also found a kink in the overflow line, got rid of that. But the engine still dies at 1/2 - 2/3 throttle. So next try - carb? Could it be a clogged filter? Any other ideas? Factor needle settings are L 1.1, H 1.5 - can't remember how mine was set up before, but I think I should still be in that ballpark, right?
btw - The engine runs fine at idle (which was where I USED to have problems...)
I'm taking the carb apart tomorrow night - maybe a clogged filter? I'm just frustrated I can't fly this plane tomorrow. Any other possible causes? Could the timing be off, i.e., Hall sensor slightly out of place?
Thanks in advance.
Save yourself and the engine some grief. Send it to Tommy at Valley View RC.
