RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 10-05-2013 | 11:26 AM
  #1448
luv2flyrc's Avatar
luv2flyrc
Originally Posted by izzy
can anyone tell me if they used the phillips head screws on the flap servos or theyy replaced them with 3mm allen bolts and nuts
i am really having a difficult time to get the screwdriver in there to close the servo
also added a 3mm spacer to the servo mount to get the servo more in line with the flap pushrod
looks like the uploader inverted the pics ,so hope it comes out right
1 pic of the electronics tray for the fuse
1 pic shows the spacer used for the flap servo
last pic shows difficulty to reach the deeper screws to close the flap servo in position ( thinking of using 3mm allen bolts and nuts to close them )
see attached pictures
I use #3 size servo screws with an Allen head. You can slip a piece of fuel tubing over your ball driver, insert the ball driver into the screw, slide the tubing down and over the head of the screw so it holds the screw in place on the ball driver, reach in, insert the screw through the servo hole and screw it in, then pull the ball driver off
Mike
