RCU Forums - View Single Post - DX18 sequencer programming help needed
Old 10-06-2013 | 04:31 AM
leopaul
Default DX18 sequencer programming help needed
I spend the whole evening yesterday trying to program the gear /door sequencer of my DX18 and it seems to be impossible to have it working the way i need.
I use the gear/brake valve all in one.So i usually program a switch that will mix 10% overtravel on the valve to activate the brake.
The problem is when you use the sequencer , the output got renamed as door and wheel and we could not do any mixes on thoose channel....So how i could activate my brake now??
If someone had some idea please, explain!!!
Thanks!!
