RCU Forums - View Single Post - A Ringmaster Bi-Plane
Old 10-06-2013 | 10:35 AM
  #34
flyingagin's Avatar
flyingagin
I finished the rear doublers that will secure the stab properly. I then glued up the front doublers. Then after much double checking that had I had the correct side so I would end up with two opposite sides and not the same (yes I have made that mistake in the past), I glued up everything Only 15 minute epoxy used for these operations.
Next I will have to make two more bulkheads, and then I can start glueing up the fuse.
Oh and I forgot to mentioned I reshaped the rudder so I could round off the back of the fuse and have it all blend in. I added a 1/2" section to the rudder to give me some room to reshape the back of it.
Ken
