RCU Forums - View Single Post - Recovering tail section around hinges?
Old 10-07-2013 | 02:22 PM
Popriv
Originally Posted by gene6029
If you cut the old hinge away just slot for the new one next to it. You could slide a piece of covering thru the hinge gap and iron it down on the top & bottom of trailing edges of the stab & the same with the elevator, then seal that with the covering on the stab/elevator, but thats alot of extra work. I'd cut the hinges away......Gene
Yes Gene, I tried cutting around the hinges and slipping the covering through the gap.... haven't had good luck though.. probably cut and rehinge?
steve
