Originally Posted by
Turbobearcat
Ok which ones from HK did you use - that is the lingering question that is buring a hole in my soul - could you post a link to the ones you used?
http://www.hobbyking.com/hobbyking/s...dProduct=17538
http://www.hobbyking.com/hobbyking/s...dProduct=28973
Use thinner wire for the struts, you don't want to add weight. Also, the metal strut on the front gear is very soft, needs to be replaced.
