Main gear doors / Hinges:
Kenrico - i see you have a spacer of some sort before the phenolic hinges ,
does this help to offset the gear doors when it opens
i read the building manual , and could not understand the 13mm brom the back corner issue ( does this mean centerline of the hinge needs to be 13mm from door or place the first hinge 13mm from corner of door panel - but then how far out does the hinge line need to be away from the door
any help appreciated
does this make sense?
thx
