No. I use Futaba with JetCat and no issue. I believe you would want to reverse the throttle channel but even so it will still do a Learn R/C. Also increase the trim step to max so with 2 clicks you can go full trim travel assuming digital trims
How do you know it does not recognize the receiver. In that it simply will not start?
