Thank you, for addressing my post however a jet turbine does have a combustion chamber which is evident in your pictures. This chamber does generate heat in a closed environment and the flash point for EPO foam is very low. How long would it take for the area subjected to this heat loose its structural integrity. Can it be measured that I can't say however the possibility does exist.
